NethServer Version: NethServer 7.8.2003
Module: LetsEncrypt
i have a problem for the renew certificate but i’m not understand error
Thank you very mutch
Module: LetsEncrypt
Your server is not fully reachable over port 80 (HTTP), I get a “403 Forbidden” error. HTTPS is working but HTTP is needed for Letsencrypt. Maybe a port forward is missing?
From the documentation:
requesting a new Let’s Encrypt [1] certificate. This is possible if the following requirements are met:
- The server must be reachable from outside at port 80. Make sure your port 80 is open to the public Internet (you can check with sites like [2]);
- The domains that you want the certificate for must be public domain names associated to server own public IP. Make sure you have public DNS name pointing to your server (you can check with sites like [3]).
Thank you for respond
the nat 80 and 443 is enabled
Yes bat the problem is not nat on router because respond nethserver and request ssl connection
reason: SSL connection required
the problem is this my file /etc/httpd/conf.d/bh_reverse.conf
SSLProxyEngine on
ProxyPass /bh/ http://192.168.0.28:8000/ flushpackets=on
ProxyPassReverse /bh/ http://192.168.0.28:8000/
SSLRequireSSL
ProxyPass /bh/ ws://192.168.0.28:8000/websocket-tunnel
ProxyPassReverse /bh/ ws://192.168.0.28:8000/websocket-tunnel
<Location /websocket-tunnel>
When browsing IP or the mail01 domain at HTTP I get the 403 Forbidden error so it seems the default page is not setup correctly.
The cloudoe domain redirects to HTTPS, this seems working.
Are there .htaccess
files in the default html dir?
ls -lisa /var/www/html/
Please share your httpd config:
config show httpd
now function if disable my file /etc/httpd/conf.d/bh_reverse.conf … i think error my fle sorry and thank youu
Thank you very mutch Markus
The certificate is update
