I unlocked the config and locked it agn, after that I was able to update the server. I cannot say what the reason was for this… I tried it a few times (just with the GUI) also with reboots and so on…
Maybe it has something to do with the hardware, it is a HP microserver Gen 10. Nethserver is running as a vm with only 2GB of RAM. We are thinking abt to buy a more powerful Server…
@fausp, The HP Microserver used to be a great server for small companies. Especially the G8. It is upgradable with more RAM and a Xeon E3-1230 (v2), Then it makes a great low-cost server for virtualization.
However, I never used a G10 and I am not sure what options the G10 has with upgrading.
As alternative I can recommend a Supermicro miniITX based server with a Xeon D-xxxx processor. VERY energy friendly with quite some processing power. And It accepts ECC memory which is recommended if you use ProxMox with ZFS…
I currently use a supermicro miniITX with a Xeon D-1521 processor. With 16GB RAM and 6 disks (1 60GB SSD for cahce, 1 250GB HDD for Proxmox system, 2 2TB HDD for raid1 ZFS pool and 2 8TB HDD for raid1 ZFS pool) This system uses around 70W on average without spinning down any disks.
Yes, I use one as backup-server (proxmox 5.x installed on zfs…) mounted via NFS for my Proxmox Hypervisor running abt. 10 VMs and to backup all of my clients with Urbackup.
A friend use it with nethserver:
[root@neth11 ~]# lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sdb 8:16 0 111.8G 0 disk
├─sdb1 8:17 0 1G 0 part /boot
└─sdb2 8:18 0 110.8G 0 part
├─VolGroup-lv_root 253:0 0 103.4G 0 lvm /
└─VolGroup-lv_swap 253:1 0 7.4G 0 lvm [SWAP]
sdc 8:32 0 3.7T 0 disk
└─sdc1 8:33 0 3.7T 0 part
└─md3 9:3 0 10.9T 0 raid5 /var/lib/nethserver
sdd 8:48 0 3.7T 0 disk
└─sdd1 8:49 0 3.7T 0 part
sde 8:64 0 3.7T 0 disk
└─sde1 8:65 0 3.7T 0 part
sdf 8:80 0 3.7T 0 disk
└─sdf1 8:81 0 3.7T 0 part
