Good evening everyone, I’m trying to develop a small PHP application. The application allows for uploading some documents to a web server (LAMP), but I can’t get it to work because I don’t know if I need to do something to enable uploads or in which directory the documents should be saved.
Hi, not sure if you are aware (just checking) that all NS8 apps are containers, so you will not find anything as before (NS7) in “/var/www” etc.. Instead everything is in containers and associated volumes.
I saw that the application is contained in a container, but if I try to upload any file to the tmp directory from my application, it works without problems. However, if I try to upload to other directories (such as “documents”), it fails.
I looked at the “max_uploads_file” setting, but it’s expressed in MB and starts at 100 MB. I tested with very small files (less than 1 MB), and it still doesn’t work.
