WOW and you come ower to my post
and make some reliable tuorial for NS !
Iām not sure what you mean, can you enlight me? thank you
You used virtual maps to send local but it is better to write only host that should goes locally , other will goes to their Domain MX record as well. Thans @zamboni you are Hi-Level Skills on NS!
I didnāt read the howto, but based on the fragment youāre creating, the right event is:
signal-event nethserver-mail-server-update
thank you giacomo
is there any explanation on how 20pseudonyms works? I mean documentation, Iād prefer instead of reading codeā¦
my idea is to add a db key to every pseudonimn⦠default value is empty, optional value is a FQDN of another server
pseudonymn fragment should read values and if that key is not empty, use itā¦
ATM no UI is necessary⦠an howto to do something like
db accounts setprop mypseudonymn ExternalServer other.server.domain.tld
should be enough
do you think my solution will work?
Iād like to discuss it
TIA
I think thereās no doc about it.
That method returns the account name (if I remember correctly, in the past it was names, for groups) associated to an email address.
Mail forwards and group expansion is implemented by /etc/postfix/aliases.
so mine solution is wrong⦠![]()
seriously, in my aliases I see:
# 40accounts -- ensure local delivery for our accounts
slfusr1 slfusr1
slfusr2 slfusr2
slfusr3 slfusr3
zamboni zamboni
I repeat, I donāt know postfix⦠should/could I work here?
On the right column you can write an external mail address (forward) or other account names (group expansion), separated by comma.
The āsame name of the left columnā form overrides the lookup on /etc/aliases file.
@davidep, did you read this one (the answer, in the 3ad)
Iām quite busy, now
Iāll surely read it, Iām very interested on this kind of configuration! Please, be patient
It could be done like a next mx record, but for this @mdv say do u need to login with external account for sending mail , or where external account mail should handle⦠so if you dont want to login like external use mail aliases as well
the solution I posted does not work
@mdv: donāt hack your server, Iām doing some tests/research
if/when Iāll find a working solution, Iāll post here
please donāt hold your breath
ok, now I read it!
I think it should be possible to do the same from the Server Manager. The example from virtualmin.com could be implemented with Users > Edit > Services > Forward messages > Email address. It changes the /etc/postfix/aliases right column, so no need for templates-custom.
However - let me say - itās a mess! POP, forwards, multiple relay domains, MX records⦠I would not like to manage similar environments! ![]()
As @alefattorini said above, we lack multi-office support. To have it, we need to modify a lot of stuff. Assuming a single PDC domain on different offices the list could be:
getent()-based Users/Groups module- multi-branch LDAP DIT layout
- mail server tables from LDAP
- ā¦
Iād like to work on it, but also NethServer 7 is on the roadmapā¦
But I donāt want think about it now: Iām going on vacation, next week ![]()
@mdv post real technical specification that You need , maybe even graphically with login from inside and outside , try to help you
OP already told us what he need in a enough clear example (re-read his last post)ā¦
something called (as @davidep says above) multi-office or, using another terminology, an hub-spokes setup
I agree with davide that OPās solution is a mess⦠with the correct hub-spokes setup, no need for external (ISP) email mailbox and pop3 collector
I did some test yesterday, two ns machines, same domain, different hostnames, all mail and dns stack installed and I come to your conclusion, we can use the forward filed/feature
I saw mail from userc (on server 2) going to usera (on server 1) but all I get is a denied message.
forward address is in the usera@server1.domain.tld form and server1.domain.tld is defined in dns hosts section
I lack some info about postfix⦠is there anyone interested in digging in?
Yep forward it is not that you need
ok⦠would you mind to elaborate a bit and give some kind of examples and a POC (Proof Of Concept)?
thank you
so in /etc/postfix/main.cf
add virtual_alias_maps = hash:/etc/postfix/mail_alias
smtpd_sender_login_maps = hash:/etc/postfix/mail_alias
in /etc/postfix/mail_alias as is posted
greyb@purpoleapple.com greyb@domain.local
shufflel@purpoleapple.com shufflel@doman.local
lightbulbm@purpoleapple.com lightbulbm@domain.local
tannerj@purpoleapple.com mail.office2.purpoleapple.com
screwups@purpoleapple.com mail.office2.purpoleapple.com
funt@purpoleapple.com mail.office2.purpoleapple.com
then run postmap /etc/postfix/mail_alias
and run service postfix restart
and in other server do the same except addresses
Ok, sounds interesting
Now, a little task for you:
Re think it in terms of custom fragments
