I’m doing some test installation of NethServer 6.6 in virtual, but I cannot reach mirrorlist.nethserver.org (error 404). Is this expected?
Thanks, regards,
Thanks, regards,
Yes the 404 is normal (missing index file).
What are you doing and what problem do you have?
Do you think that a simpe web page could be better?
Something like http://packages.nethserver.org/?
Do you reach other destinations?
I’m very sorry to have summoned you, guys, PEBKAC
It was a local DNS resolution problem, not a NethServer infrastructure problem. I need some sleep.
Thanks anyways for the support.
