gpunk
(remix)
December 2, 2020, 2:51pm
#1
Thanks a million for this new release !
I enjoy very much the version upgrade on NC for example
The only thing I had to do, if override the hard-coded limitation of “maxelem” in “/usr/share/nethserver-blacklist/load-ipsets” line: 111.
The machine I use is very happy with 8388608 instead of 131072 .
giacomo
(Giacomo Sanchietti)
December 3, 2020, 7:50am
#2
That is an arbitrary limit: https://github.com/NethServer/nethserver-blacklist/commit/3c72879dd258c8e65dfe05ff92cc3bd11a82d2d0
I did some researches before setting it, and the current value seemed a good compromise between performance and used memory.
We could increase it but I fear memory problem on small machines.
What do you think @dev_team ?
Not an expert, but we are using double the default value, I think 128k IPs is a high number.
I think we could accept a patch reading a prop for maxelem
stephdl
(Stéphane de Labrusse)
December 10, 2020, 3:56pm
#7
something to test, please come on
opened 03:49PM - 10 Dec 20 UTC
The maxelem value of ipset is set to 131072 but in some cases we might need to increase it
Proposed solution
I propose...
testing
giacomo
December 16, 2020, 10:52am
#8
gpunk
(remix)
January 16, 2021, 10:31am
#9
Thank you very much,
It works like a charm .
Cheers
