Implementation of FaxServer to NS8
hi, i’'ve a question.
if possible to implementing FaxServer service to ns8?
i’ve a lot of client about need these service
thank you.
It occurs to me that you could handle this using a “fax-to-email” service provided by your phone provider:
You can have faxes sent to a mailbox and then download them using imapsync to a designated internal mailbox, which you can then share with others.
To send faxes, if the recipient’s address is in the format faxnumber@yourprovider.tld, you can set up a relay with the recipient set to yourprovider.tld
I just came up with this on the spot—maybe it’ll work :slight_smile:
