I logged into the nethserver cockpit and changed my admin user’s password.
I then tried to ssh as admin using the old password and the new one I just set.
I was able to log into nethserver using both old and new password (ssh and cockpit).
I did install DUO which appears to have caused the issue.
Which user had password changed? root
Which is your Account Provider?
You can have a AD container as account provider
Or an OpenLDAP instance
Which one is configured into your NethServer?
I found that this issue appears to have been introduced when I installed DUO on the server.
Hi @sv2015vs
Well, it seems you debunked some of the “myths” on their webpage about security and access…
