How would I allot more than 256 addresses on a network?
My local LAN needs 300 or more IP addresses. I would rather not divide the network into smaller subnets, if that can be avoided. Is there a way to create a DHCP network in NS that uses more than 256 addresses?
This may be the purpose of “alias” IPs, but I’m not familiar with that term and I’m not sure how to use it.
You can use a class a o class b network address
10.0.0.0 - 10.255.255.255 class a is too big, but you can still use it.
class b is better
172.16.0.0 - 172.31.255.255, for example 172.16.1.0 to 172.16.2.254
Of course! Thank you, Jose.
