fausp
(fpausp)
January 13, 2018, 1:39pm
1
Today I tried to follow the Wiki - How to manually configure a RAID1 - , but when/after I mount md3 as described, I cannot reach some Entries. For example to configure a static IP under Network …
Here is the link to the Wiki-Howto:
fausp
(fpausp)
January 13, 2018, 2:01pm
2
OK, sorry folks. I got it now. I thought “Copy existing data” stands only for userdata…
fausp
(fpausp)
January 14, 2018, 11:14am
3
Tried it on another Server and got this:
[root@neth11 ~]# mkfs.xfs /dev/md3 -f
meta-data=/dev/md3 isize=512 agcount=32, agsize=91567744 blks
= sectsz=4096 attr=2, projid32bit=1
= crc=1 finobt=0, sparse=0
data = bsize=4096 blocks=2930164224, imaxpct=5
= sunit=128 swidth=384 blks
naming =version 2 bsize=4096 ascii-ci=0 ftype=1
log =internal log bsize=4096 blocks=521728, version=2
= sectsz=4096 sunit=1 blks, lazy-count=1
realtime =none extsz=4096 blocks=0, rtextents=0
mkfs.xfs: libxfs_device_zero write failed: Input/output error
Any Suggestions what I can do? Is it possible to use ext3 instead?
mrmarkuz
(Markus Neuberger)
January 15, 2018, 9:06am
4
Could it be a hardware error?
linux, filesystems, xfs
fausp
(fpausp)
January 15, 2018, 10:42am
5
Yes, you are right. The disk is on the way back to ama… Thank you !
