Module: Domain and users
Hi everyone! I’m new to NethServer and am testing it for deployment in a small company.
I noticed that NethServer 8 has some limitations, one of which is that you can’t add multiple groups to a Share.
- I created a Windows 10 Virtual Machine and installed RSAT. I tested GPOs (worked well), creating users and groups (worked well), and changing ACLs on shares (didn’t work 100%).
- I use RSAT’s Shared Folders to assign permissions to access the share. It works well.
- To assign permissions to a folder, I go to Explorer > Network > \fileserver > Properties on the desired Share > Security > Add.
However, in some cases, permissions aren’t assigned to all folders.
- For example, I already had the TEST folder created with some files. I added a new group to the share, but it’s not applying the ACL to the other folders.
- When I check the “Replace all child object permission entries with inheritable permission entries from this object” option, I get an access denied message.
I don’t know what to do, since I can’t add ACLs via Samba or SSH the way I know them.
I don’t have much experience with this type of application; it’s my first time. I’ve only worked with AD a few times, so I only know the basics.
Thank you all for your attention.
