NethServer Version: 7.9.2009
I tried to join my Active Directory Domain with my Windows 8.1 Pro PC.
It says the Domain could not be contacted.
Error:
dcdiag.txt
My hosts file:
My AD Nethserver configuration:
What I am trying to setup:
Error:
dcdiag.txt
From my limited experience joining Windows AD to Nethserver I did the following:
I changed my DNS settings, checked 3. (I think success) and used the FQDN. After that I needed to login. I did this and I recieved an error.
My outputs:
Hi, perhaps a wrong error message? You have to be AD-Admin to add the client? Is the user Admin(windows) a AD-Admin?
I can’t 100% remember my problems connecting windows clients but something with the user-rights and wrong message errors… If you think “stupid reply” - ignore my suggestions!
maddin
I shitted up my whole configuration, I think I should reinstall my Windows installation.
