Great explanation, it looks a good use case for guacamole
As 2FA is more and more in use
Would it be possible to implement TOPT in this package?
https://guacamole.apache.org/doc/gug/totp-auth.html
Kind Regards
Shodan
I’m going to add it in the next update.
For now you may put the jar to /var/lib/guacamole/extensions/ and reapply the configuration with:
signal-event nethserver-guacamole-update
See also:
Works like a charm
thanks and thanks for including it so I do not need to worry about updates ;).
short remark I first got a problem that the enrollment did not start reason needed to clear my browser cache.
Regards
Shodan
