I have been looking for a task program for a small group of people to share and categorize/prioritize tasks. It is essential to be able to sync those over the air between devices and everybody has to be able to change the solution.
The same goes for Brainstorming. Looking for a solution to do this were several people can do this from any device.
Everything I have found is not open source and in the cloud which makes it difficult if you have information that you don’t want to share.
Anyone who has a suggestion for a solution? Preferable on Premises solution.
I found Taiga which I felt was the best option. You can start online and then export your project and import it to your private installation. Thit is true open source when it’s best!
