Hello everyone, I own a docker and grafana server. I was wondering if it would be possible to configure Grafana to monitor in toto apache2 . Thank you
Hi @france
Simple enough…
Install Zabbix Agent2.
Use the httpd module for agent2. This gives a lot of data…
Feed the results directly to Grafana or via Zabbix (Also can integrate Grafana)…
Hi Andy , you agent is installed on neth and sukl my zabbix server poss add http . But how do I send the data to grafana as a zabbix?
Not so hard:
or
both is better!
