I use Proxmox and all my servers are virtual machines… I tought its time to try Nethserver and replace my SME9…
Today I copied my data from the SME9 to the new Installed Nethserver 7.3. I used Windows 7 explorer and made three sessions at the same time, after about 10min the filesystem crashed.
I was not able to shutdown the Nethserver, a reboot did also not work. At the moment I have only screenshots, I will send you the logfile after I can extract it from the vm…
Everything seems ok.
Also dnutan howto seems to be pretty good.
I prefer to use scsi as disk type (linux seems to prefer that kind of configuration), it’s a lot better as compatibility and you lose just a 1-2% performance compared to virtio. But that’s just a matter of taste.
Also I don’t use qcow format, cause I use ZFS as storage subsystem in proxmox.
