When trying to connect my new nethserver version 7.9.2009 that I am going to use to filter content to an Ad in windows server 2008 r2 standard it gives me the following error:
Error
Unedited configuration.
The following command has failed:
system-accounts-provider/update
Unfortunately, we couldn’t spot the exact error. If you want to help, click the button below to copy the failed command to the clipboard, paste it into Terminal and send the command output to the developers.
then when executing the command in the terminal it tells me:
echo ‘{“StartTls”:“disabled”,“BindPassword”:“cuspal2022*01”,“BaseDN”:“OU=CUSPAL,DC=cuspal,DC=gob,DC=ve”,“BindDN”:“glpi”,“LdapURI”:“ldap://da-cuspal-02.cuspal.gob.ve”,“UserDN”:“DC=cuspal,DC=gob,DC=ve”,“GroupDN”:“DC=cuspal,DC=gob,DC=ve”,“action”:“bind-credentials”}’ | /usr/bin/setsid /usr/bin/sudo /usr/libexec/nethserver/api/system-accounts-provider/update | jq
“steps”: 6,
“pid”: 4302,
“args”: “”,
“event”: “nethserver-sssd-save”
“step”: 1,
“pid”: 4302,
“action”: “S01nethserver-sssd-cleanup”,
“event”: “nethserver-sssd-save”,
“state”: “running”
“progress”: “0.17”,
“time”: “0.071164”,
“exit”: 0,
“state”: “done”,
“step”: 1,
“pid”: 4302,
“step”: 2,
“pid”: 4302,
“action”: “S05generic_template_expand”,
“state”: “running”
“progress”: “0.33”,
“time”: “0.222994”,
“exit”: 0,
“state”: “done”,
“step”: 2,
“pid”: 4302,
“step”: 3,
“pid”: 4302,
“action”: “S20nethserver-sssd-conf”,
“state”: “running”
“progress”: “0.50”,
“time”: “0.321791”,
“exit”: 0,
“state”: “done”,
“step”: 3,
“pid”: 4302,
“step”: 4,
“pid”: 4302,
“action”: “S30nethserver-sssd-initkeytabs”,
“state”: “running”
“progress”: “0.67”,
“time”: “0.532742”,
“exit”: 1280,
“state”: “done”,
“step”: 4,
“pid”: 4302,
“step”: 5,
“pid”: 4302,
“action”: “S80nethserver-sssd-notifyclients”,
“state”: “running”
“progress”: “0.83”,
“time”: “0.270168”,
“exit”: 0,
“state”: “done”,
“step”: 5,
“pid”: 4302,
“step”: 6,
“pid”: 4302,
“action”: “S90adjust-services”,
“state”: “running”
“progress”: “1.00”,
“time”: “1.19539”,
“exit”: 0,
“state”: “done”,
“step”: 6,
“pid”: 4302,
“pid”: 4302,
“status”: “failed”,
[root@proxy ~]#
can you help me solve it
