pagaille
(Matthieu Gaillet)
September 18, 2019, 10:34am
1
That rule in /etc/fail2ban/filter.d/asterisk.conf is supposed to catch anonymous calls that tries to call you from nowhere :
^%(__prefix_line)s%(log_prefix)s "Rejecting unknown SIP connection from <HOST>"$
But it doesn’t work. I’ve tons of such messages in my logs that don’t trigger the filter :
"Rejecting unknown SIP connection from 158.69.55.234:52420"
I guess that the port mentioned after the IP that keeps the regex matching the string. Fixing it will probably be a piece of cake for @stephdl ?
Txs
pagaille
(Matthieu Gaillet)
September 18, 2019, 1:35pm
2
The answer is probably the following. At least preliminary tests shows that it works :
^%(__prefix_line)s%(log_prefix)s "Rejecting unknown SIP connection from <HOST>:.*"$
Note the :.* string at the end.
stephdl
(Stéphane de Labrusse)
September 18, 2019, 5:02pm
3
we have made a custom filter file for that case we have to add it
stephdl
September 18, 2019, 5:25pm
4
@Stll0 what do you think … Could please check an asterisk server (with fail2ban) and check which IP has filled your log with login attempts
We could add more filter lines
stephdl
September 18, 2019, 6:06pm
5
pagaille
(Matthieu Gaillet)
September 19, 2019, 6:46am
6
Actually that’s an existing filter which don’t work. I believe that the logs have evolved and that asterisk added the port later, breaking that fail2ban rule.
stephdl
September 19, 2019, 3:06pm
7
Would it be possible you double check inside the log and watch about attempts that we are missing ?
pagaille
(Matthieu Gaillet)
September 19, 2019, 5:12pm
8
Sure. For what I can see there is no other missed string. The existing regexes are quite exhaustive.
stephdl
September 25, 2019, 1:18pm
9
@pagaille could you please valid the new regex, we could release it to everybody
opened 12:53PM - 25 Sep 19 UTC
closed 07:00AM - 01 Oct 19 UTC
verified
**Steps to reproduce**
run an asterisk server
some attempt to unknow sip log… in are not banned
`Rejecting unknown SIP connection from 158.69.55.234:52420`
**Expected behavior**
I expect that the attempts are banned
**Actual behavior**
the attempts are not banned because fail2ban regex doesn't expect a port number ends the line in logs
**Components**
nethserver-fail2ban-1.1.7-1.ns7.noarch
**See also**
https://community.nethserver.org/t/fail2ban-again-not-catching-some-asterisk-log-strings/13411/1
thank @matthieu
pagaille
(Matthieu Gaillet)
September 25, 2019, 2:00pm
10
Not working. The conf file doesn’t get updated ??
Downloading packages:
nethserver-fail2ban-1.1.10-1.ns7.noarch.rpm | 912 kB 00:00:00
Running transaction check
Running transaction test
Transaction test succeeded
Running transaction
Installing : nethserver-fail2ban-1.1.10-1.ns7.noarch 1/1
Verifying : nethserver-fail2ban-1.1.10-1.ns7.noarch 1/1
Installed:
nethserver-fail2ban.noarch 0:1.1.10-1.ns7
Complete!
[root@mattlabs ~]# cat /etc/fail2ban/filter.d/asterisk_nethserver.conf
# Fail2Ban filter for asterisk authentication failures
# stephane de Labrusse <stephdl@de-labrusse.fr>
[INCLUDES]
# Read common prefixes. If any customizations available -- read them from
# common.local
before = common.conf
[Definition]
_daemon = asterisk
__pid_re = (?:\[\d+\])
iso8601 = \d{4}-\d{2}-\d{2}T\d{2}:\d{2}:\d{2}\.\d+[+-]\d{4}
# All Asterisk log messages begin like this:
log_prefix= (?:NOTICE|SECURITY|WARNING)%(__pid_re)s:?(?:\[C-[\da-f]*\])? [^:]+:\d*(?:(?: in)? \w+:)?
failregex = ^%(__prefix_line)s%(log_prefix)s <HOST> failed to authenticate as '.*'$
^%(__prefix_line)s%(log_prefix)s <HOST> tried to authenticate with nonexistent user '.*'$
^%(__prefix_line)s%(log_prefix)s <HOST> failed to pass IP ACL as '.*'$
ignoreregex =
[root@mattlabs ~]#
stephdl
September 25, 2019, 8:03pm
11
please install directly the testing package from GH, you can pick up the link from X86_64
yum install http://packages.nethserver.org/nethserver/7.7.1908/testing/x86_64/Packages/nethserver-fail2ban-1.1.10-1.6.g7771945.ns7.noarch.rpm
pagaille
(Matthieu Gaillet)
September 26, 2019, 7:36am
12
Yep, working !
[2019-09-19 09:40:53] WARNING[31782][C-000003bc] Ext. s: "Rejecting unknown SIP connection from 198.23.151.90:5085"
Txs mate
