Seems to be an issue with the collectd service itself?
Jul 30 10:28:18 remote collectd[26860]: plugin_load: plugin “threshold” successfully loaded.
Jul 30 10:28:18 remote collectd[26860]: plugin_load: plugin “unixsock” successfully loaded.
Jul 30 10:28:18 remote systemd: collectd.service: main process exited, code=exited, status=1/FAILURE
Jul 30 10:28:18 remote systemd: Failed to start Collectd statistics daemon.
Jul 30 10:28:18 remote systemd: Unit collectd.service entered failed state.
Jul 30 10:28:18 remote systemd: collectd.service failed.
Jul 30 10:28:18 remote systemd: collectd.service holdoff time over, scheduling restart.
Jul 30 10:28:18 remote systemd: Starting Collectd statistics daemon…
Jul 30 10:28:18 remote collectd[26863]: plugin_load: plugin “syslog” successfully loaded.
Jul 30 10:28:18 remote collectd[26863]: plugin_load: plugin “rrdtool” successfully loaded.
Jul 30 10:28:18 remote collectd[26863]: plugin_load: plugin “cpu” successfully loaded.
Jul 30 10:28:18 remote collectd[26863]: plugin_load: plugin “processes” successfully loaded.
Jul 30 10:28:18 remote collectd[26863]: plugin_load: plugin “uptime” successfully loaded.
Jul 30 10:28:18 remote collectd[26863]: plugin_load: plugin “match_regex” successfully loaded.
Jul 30 10:28:18 remote collectd[26863]: plugin_load: plugin “md” successfully loaded.
Jul 30 10:28:18 remote collectd[26863]: plugin_load: plugin “load” successfully loaded.
Jul 30 10:28:18 remote collectd[26863]: plugin_load: plugin “df” successfully loaded.
Jul 30 10:28:18 remote collectd[26863]: plugin_load: plugin “memory” successfully loaded.
Jul 30 10:28:18 remote collectd[26863]: plugin_load: plugin “swap” successfully loaded.
Jul 30 10:28:18 remote collectd[26863]: plugin_load: plugin “interface” successfully loaded.
Jul 30 10:28:18 remote collectd[26863]: plugin_load: plugin “disk” successfully loaded.
Jul 30 10:28:18 remote collectd[26863]: plugin_load: plugin “ping” successfully loaded.
Jul 30 10:28:18 remote collectd[26863]: ping plugin: MaxMissed < 0, disabled re-resolving of hosts
Jul 30 10:28:18 remote collectd[26863]: plugin_load: plugin “python” successfully loaded.
Jul 30 10:28:18 remote collectd[26863]: python plugin: Error importing module “nethserver_alerts”.
Jul 30 10:28:18 remote collectd[26863]: Unhandled python exception in importing module: ImportError: No module named nethserver_alerts
Jul 30 10:28:18 remote collectd[26863]: python plugin: Found a configuration for the “nethserver_alerts” plugin, but the plugin isn’t loaded or didn’t register a configuration callback.
Jul 30 10:28:18 remote collectd[26863]: plugin_load: plugin “threshold” successfully loaded.
Jul 30 10:28:18 remote collectd: Error: Reading the config file failed!
Jul 30 10:28:18 remote collectd: Read the logs for details.
Jul 30 10:28:18 remote collectd[26863]: plugin_load: plugin “unixsock” successfully loaded.
Jul 30 10:28:18 remote collectd[26865]: plugin_load: plugin “syslog” successfully loaded.
Jul 30 10:28:18 remote collectd[26865]: plugin_load: plugin “rrdtool” successfully loaded.
Jul 30 10:28:18 remote collectd[26865]: plugin_load: plugin “cpu” successfully loaded.
Jul 30 10:28:18 remote collectd[26865]: plugin_load: plugin “processes” successfully loaded.
Jul 30 10:28:18 remote collectd[26865]: plugin_load: plugin “uptime” successfully loaded.
Jul 30 10:28:18 remote collectd[26865]: plugin_load: plugin “match_regex” successfully loaded.
Jul 30 10:28:18 remote collectd[26865]: plugin_load: plugin “md” successfully loaded.
Jul 30 10:28:18 remote collectd[26865]: plugin_load: plugin “load” successfully loaded.
Jul 30 10:28:18 remote collectd[26865]: plugin_load: plugin “df” successfully loaded.
Jul 30 10:28:18 remote collectd[26865]: plugin_load: plugin “memory” successfully loaded.
Jul 30 10:28:18 remote collectd[26865]: plugin_load: plugin “swap” successfully loaded.
Jul 30 10:28:18 remote collectd[26865]: plugin_load: plugin “interface” successfully loaded.
Jul 30 10:28:18 remote collectd[26865]: plugin_load: plugin “disk” successfully loaded.
Jul 30 10:28:18 remote collectd[26865]: plugin_load: plugin “ping” successfully loaded.
Jul 30 10:28:18 remote collectd[26865]: ping plugin: MaxMissed < 0, disabled re-resolving of hosts
Jul 30 10:28:18 remote collectd[26865]: plugin_load: plugin “python” successfully loaded.
Jul 30 10:28:18 remote collectd[26865]: python plugin: Error importing module “nethserver_alerts”.
Jul 30 10:28:18 remote collectd[26865]: Unhandled python exception in importing module: ImportError: No module named nethserver_alerts
Jul 30 10:28:18 remote collectd[26865]: python plugin: Found a configuration for the “nethserver_alerts” plugin, but the plugin isn’t loaded or didn’t register a configuration callback.
Jul 30 10:28:18 remote collectd[26865]: plugin_load: plugin “threshold” successfully loaded.
Jul 30 10:28:18 remote collectd[26865]: plugin_load: plugin “unixsock” successfully loaded.
Jul 30 10:28:18 remote collectd[26866]: plugin_load: plugin “syslog” successfully loaded.
Jul 30 10:28:18 remote collectd[26866]: plugin_load: plugin “rrdtool” successfully loaded.
Jul 30 10:28:18 remote collectd[26866]: plugin_load: plugin “cpu” successfully loaded.
Jul 30 10:28:18 remote collectd[26866]: plugin_load: plugin “processes” successfully loaded.
Jul 30 10:28:18 remote collectd[26866]: plugin_load: plugin “uptime” successfully loaded.
Jul 30 10:28:18 remote collectd[26866]: plugin_load: plugin “match_regex” successfully loaded.
Jul 30 10:28:18 remote collectd[26866]: plugin_load: plugin “md” successfully loaded.
Jul 30 10:28:18 remote collectd[26866]: plugin_load: plugin “load” successfully loaded.
Jul 30 10:28:18 remote collectd[26866]: plugin_load: plugin “df” successfully loaded.
Jul 30 10:28:18 remote collectd[26866]: plugin_load: plugin “memory” successfully loaded.
Jul 30 10:28:18 remote collectd[26866]: plugin_load: plugin “swap” successfully loaded.
Jul 30 10:28:18 remote collectd[26866]: plugin_load: plugin “interface” successfully loaded.
Jul 30 10:28:18 remote collectd[26866]: plugin_load: plugin “disk” successfully loaded.
Jul 30 10:28:18 remote collectd[26866]: plugin_load: plugin “ping” successfully loaded.
Jul 30 10:28:18 remote collectd[26866]: ping plugin: MaxMissed < 0, disabled re-resolving of hosts
Jul 30 10:28:18 remote collectd[26866]: plugin_load: plugin “python” successfully loaded.
Jul 30 10:28:18 remote collectd[26866]: python plugin: Error importing module “nethserver_alerts”.
Jul 30 10:28:18 remote collectd[26866]: Unhandled python exception in importing module: ImportError: No module named nethserver_alerts
Jul 30 10:28:18 remote collectd[26866]: python plugin: Found a configuration for the “nethserver_alerts” plugin, but the plugin isn’t loaded or didn’t register a configuration callback.
Jul 30 10:28:18 remote collectd[26866]: plugin_load: plugin “threshold” successfully loaded.
Jul 30 10:28:18 remote collectd[26866]: plugin_load: plugin “unixsock” successfully loaded.
Jul 30 10:28:19 remote systemd: collectd.service holdoff time over, scheduling restart.
Jul 30 10:28:19 remote systemd: Starting Collectd statistics daemon…
Jul 30 10:28:19 remote collectd[26876]: plugin_load: plugin “syslog” successfully loaded.
Jul 30 10:28:19 remote collectd[26876]: plugin_load: plugin “rrdtool” successfully loaded.
Jul 30 10:28:19 remote collectd[26876]: plugin_load: plugin “cpu” successfully loaded.
Jul 30 10:28:19 remote collectd[26876]: plugin_load: plugin “processes” successfully loaded.
Jul 30 10:28:19 remote collectd[26876]: plugin_load: plugin “uptime” successfully loaded.
Jul 30 10:28:19 remote collectd[26876]: plugin_load: plugin “match_regex” successfully loaded.
Jul 30 10:28:19 remote collectd[26876]: plugin_load: plugin “md” successfully loaded.
Jul 30 10:28:19 remote collectd[26876]: plugin_load: plugin “load” successfully loaded.
Jul 30 10:28:19 remote collectd[26876]: plugin_load: plugin “df” successfully loaded.
Jul 30 10:28:19 remote collectd[26876]: plugin_load: plugin “memory” successfully loaded.
Jul 30 10:28:19 remote collectd[26876]: plugin_load: plugin “swap” successfully loaded.
Jul 30 10:28:19 remote collectd[26876]: plugin_load: plugin “interface” successfully loaded.
Jul 30 10:28:19 remote collectd[26876]: plugin_load: plugin “disk” successfully loaded.
Jul 30 10:28:19 remote collectd[26876]: plugin_load: plugin “ping” successfully loaded.
Jul 30 10:28:19 remote collectd[26876]: ping plugin: MaxMissed < 0, disabled re-resolving of hosts
Jul 30 10:28:19 remote collectd[26876]: plugin_load: plugin “python” successfully loaded.
Jul 30 10:28:19 remote collectd[26876]: python plugin: Error importing module “nethserver_alerts”.
Jul 30 10:28:19 remote collectd[26876]: Unhandled python exception in importing module: ImportError: No module named nethserver_alerts
Jul 30 10:28:19 remote collectd[26876]: python plugin: Found a configuration for the “nethserver_alerts” plugin, but the plugin isn’t loaded or didn’t register a configuration callback.
Jul 30 10:28:19 remote collectd[26876]: plugin_load: plugin “threshold” successfully loaded.
Jul 30 10:28:19 remote collectd: Error: Reading the config file failed!
Jul 30 10:28:19 remote collectd: Read the logs for details.
Jul 30 10:28:19 remote collectd[26876]: plugin_load: plugin “unixsock” successfully loaded.
Jul 30 10:28:19 remote systemd: collectd.service: main process exited, code=exited, status=1/FAILURE
Jul 30 10:28:19 remote systemd: Failed to start Collectd statistics daemon.
Jul 30 10:28:19 remote systemd: Unit collectd.service entered failed state.
Jul 30 10:28:19 remote systemd: collectd.service failed.
Jul 30 10:28:19 remote systemd: start request repeated too quickly for collectd.service
