rspamd 1.7.6 is available in testing
yum update --enablerepo=nethserver-testing rspamd
After Installation i see this in History:
| 23.6.2018, 07:50:57 | controller | 12829 | cannot load json data: parse error error while parsing : line: 5, column: 0 - ‘string value must not be empty’, character: ‘0x0a’ | ||
| 23.6.2018, 07:50:57 | rspamd_proxy | 12828 | cannot load json data: parse error error while parsing : line: 5, column: 0 - ‘string value must not be empty’, character: ‘0x0a’ | ||
| 23.6.2018, 07:50:57 | fuzzy | 12827 | cannot load json data: parse error error while parsing : line: 5, column: 0 - ‘string value must not be empty’, character: ‘0x0a’ |
no problem on my side, restart rspamd and check again please
have restart it and:
| 23.6.2018, 07:59:24 | controller | 13662 | cannot load json data: parse error error while parsing : line: 5, column: 0 - ‘string value must not be empty’, character: ‘0x0a’ | ||
| 23.6.2018, 07:59:24 | rspamd_proxy | 13661 | cannot load json data: parse error error while parsing : line: 5, column: 0 - ‘string value must not be empty’, character: ‘0x0a’ | ||
| 23.6.2018, 07:59:24 | fuzzy | 13660 | cannot load json data: parse error error while parsing : line: 5, column: 0 - ‘string value must not be empty’, character: '0x0a |
yum downgrade rspamd
after downgrade:
| 23.6.2018, 08:01:56 | controller | 13970 | cannot load json data: parse error error while parsing : line: 5, column: 0 - ‘string value must not be empty’, character: ‘0x0a’ | ||
| 23.6.2018, 08:01:56 | rspamd_proxy | 13969 | cannot load json data: parse error error while parsing : line: 5, column: 0 - ‘string value must not be empty’, character: ‘0x0a’ | ||
| 23.6.2018, 08:01:56 | fuzzy | 13968 | cannot load json data: parse error error while parsing : line: 5, column: 0 - ‘string value must not be empty’, character: ‘0x0a’ |
rpm -qa rspamd
rspamd-1.7.5-1.x86_64
reboot
after reboot:
| 23.6.2018, 08:09:09 | controller | 2886 | map | pr5857 | cannot resolve updates.rspamd.com |
| 23.6.2018, 08:09:09 | controller | 2886 | map | xa6qqy | cannot resolve rspamd.com |
| 23.6.2018, 08:09:09 | controller | 2886 | map | fdp86m | cannot resolve maps.rspamd.com |
| 23.6.2018, 08:09:09 | controller | 2886 | map | k8f914 | cannot resolve maps.rspamd.com |
| 23.6.2018, 08:09:06 | controller | 2886 | lua | bgayez | cannot upload script to /var/run/redis-rspamd/rspamd(00000000408F02C0): timeout while connecting the server |
| 23.6.2018, 08:09:06 | controller | 2886 | lua | bgayez | cannot upload script to /var/run/redis-rspamd/rspamd(0000000041C158D0): timeout while connecting the server |
systemctl status redis-rspamd
[root@sbs ~]# systemctl status redis-rspamd
● redis-rspamd.service - Redis persistent key-value database Rspamd
Loaded: loaded (/usr/lib/systemd/system/redis-rspamd.service; enabled; vendor preset: disabled)
Active: active (running) since Sat 2018-06-23 08:08:40 CEST; 8min ago
Main PID: 753 (redis-server)
CGroup: /system.slice/redis-rspamd.service
└─753 /usr/bin/redis-server 127.0.0.1:0
Jun 23 08:08:40 xxx.xxx.xxx systemd[1]: Started Redis persistent key-v…
Jun 23 08:08:40 xxx.xxx.xxxsystemd[1]: Starting Redis persistent key-…
Hint: Some lines were ellipsized, use -l to show in full.
what are the error message; do a pastebin of last lines /var/log/maillog
can you display the history ?
dont see errror messages in the mail log.
Jun 23 08:22:22 sbs rspamd[2886]: <23aba0>; csession; rspamd_controller_check_password: allow unauthorized connection from a trusted IP 127.0.0.1
Jun 23 08:22:22 sbs rspamd[2886]: <8b9e04>; csession; rspamd_controller_check_password: allow unauthorized connection from a trusted IP 127.0.0.1
yep i can display the history, is also normal like before
so it works but you loaded some error at boot ???
i installed the 1.7.6 again, guess it works. get this messages like before:
23.6.2018, 08:15:07 controller 2886 csession d1ceec got IO timeout with server fuzzy.rspamd.com(88.99.142.95:11335), after 1 retransmits
nope, no errors at boot
