Did it worked?
on My server it works , after couple of days @medworthy will test this feature on his server and update those topic
It did work but I would suggest that people check to see if their client software allows for this feature (not all jabber / xmpp IM clients support this and / or other XEP standards)
Letās share everything with us!
@Nas @medworthy
Could you share please your notes?
Can someone please share the xmpp client name for Linux which can work correctly with eJabberd and carbon messages? Please donāt send links to documentations if you never tried these clients yourself because they all ādo supportā something but donāt work some reason.
Have you compiled module for carbon?
@medworthy please share your investigation. We have tried IMpro and vacuum as far as i remember ā¦
yes.
eJabberd 16.01
carbon module gave some erros during compilation, but this thread helped.
Then I got erros during module loading, but replacing this line:
IQDisc = gen_mod:get_opt(iqdisc, Opts, one_queue),
to this
IQDisc = gen_mod:get_opt(iqdisc, Opts, fun gen_iq_handler:check_type/1, one_queue),
helped. Now it is loading with no erros, but I still can`t see my own messages in another clients.
right now I`m using Jitsi on ubuntu 14.04 and ubuntu 15.10
Are you sure you need a specific client? Carbon copy would be a server thing. BTW on Linux best jabber client is pidgin
Client should send info to the server about carbon copy
I`m okay with any solution. Just tell me the combination of server/client which will 100% work
Vacuum
tested Pidgin: it is not even able to receive messages simultaneously on both clients (only 1 to 1 chat is possible).
tested vacuum: it is working similar to Jitsi - can receive messages on both clients, but sent messages are visible only on sender`s client (not on both).
that said, youād start to tell us exactly what do you expect from the client and server, because (maybe) youāre looking for something that is not implemented yet (and Iām not referring to NS)
moreover, going OT, may I ask you to change your profile setup and change the dot in something more readable? I follow this community via email client and messages from you are likely to be flagged as spamā¦
Thank you in advance
