Have a nice holiday
Thank you!
from the multimap you could have a new map (you have to make a template, before FORBIDDEN_FILE_EXTENSION)
FILENAME_ACCEPT {
type = âfilenameâ;
filter = âextensionâ;
map = â${CONFDIR}/filenameAccepted.mapâ;
action = âacceptâ;
you have other exemple in the multimap module with regex, could you try to send me you dwg to stephdl at de-labrusse dot fr
Just in case to see if my server does the same
Sent.
Here we are:
The mail system
<[stephdl@de-labrusse.fr](https://domain.eu/webtop/stephdl@de-labrusse.fr)>: host mail.de-labrusse.fr[164.132.77.216] said: 554
5.7.1 Forbidden attachment name extension (in reply to end of DATA command)
well you found a bug
a workaround would be to use an archive to send the dwg ?
Not really comfortable⊠also because we block archives. We can use Webtop Cloud as temporary solution⊠but users want to send dwg via email.
my job without users nor customers would be so nice
I can send a dwf to my server
downloaded from http://lparchitectes.pagesperso-orange.fr/Plans/171a.dwf
Are you sure that your users love you ?
Not really
