Right, but there will be a new full backup done each week.
From doc : Each backup is on its own folder named after the current timestamp. Files that haven’t changed from one backup to the next are hard-linked to the previous backup so take very little extra space.
Therefore, changed files are simply copied in the current backup folder.
NB : Older versions are kept (versioning) ! The script automatically deletes old backups using the following logic:
Within the last 24 hours, all the backups are kept. Within the last 31 days, the most recent backup of each day is kept. After 31 days, only the most recent backup of each month is kept. Additionally, if the backup destination directory is full, the oldest backups are deleted until enough space is available.
The RAM isn’t as big a deal as the hacking that would be needed to get Neth installed on ZFS in a way that’s stable, repeatable, and would survive upgrades without any extra work. Other Linux flavors make this a bit easier, but not CentOS. I do like the idea (and, again, this use case would be perfect for snapshots and replication, though it would require another ZFS box to send them to), but it would take a lot more work before I think it’d be safe to use for production.
@pagaille I opened you a pull request to create the marker automatically. I also cleaned up some unused variables.
While I really appreciate your efforts, I don’t think that this is ready for inclusion in the core backup-data of NethServer.
Don’t get me wrong, I quickly reviewed the script and I think that we should go ahead, but I need to involve more people (@giacomo, @Stll0).
The first thing we must check is the inclusion/exclusion syntax of duplicity vs rsync.
I fear that we may leave out some files in the backup and include too much when there are exclusions.
We may adopt a syntax for the include/exclude files in /etc/backup-data.d/ and convert them appropriately to the format needed by the tool we use.
Then we must work on the restore interface.
We may need a function (a button on the interface) to format the usb local disk as needed.
I see that rsync-time-backup have some checks for the destination, but I don’t know if those are enough.
I didn’t test backup over ssh, I think it would be a good option.
@pagaille would you like to coordinate our efforts?
Thanks so much for your interest @filippo_carletti ! My first impression was that you wasn’t convinced of the advantages of this script
Sure. As stated above, this is a work in progress that needs an UI and lot of testing.
It runs for some weeks here however, until now without any problem.
I already took care of this. I adapted the include and exclude files handling in the script so that rsync can use them. As far as I can tell, it works. The file format doesn’t have to be modified.
Yep. I’ve got an idea, I’ll try to write a draft.
Yes. It is missing currently.
Since nethserver-backup takes care of the mounting I see no reason why something could go wrong.
Me too ! It is a nice and easy alternative to webdav !
LOL.
We can meet in a reserved room at fosdem.
I put your rsync backup in production, I’m keeping an eye on it.
I would like to work on the restore.
Open issues:
just a suggestion: expiration should be done after current backup job has finished
otherwise, it your retention policy is very “short”, you’d find yourself with no good backup
Absolutely. I love the dumb approach : HDD not full ? --> fill it. HDD full ? --> delete oldest backups until there is enough space. The user doesn’t have to worry and enjoys as much backups as the device can handle.
Do you know how time machine performs a restore? I’ve read some user documentation, but I can’t figure out quickly how it works behind the scenes (I don’t know macOS).
We could scan the first level of the backup disk to quickly know the dates of all backups (find /mnt/backup/servername/ -maxdepth 1 -type d), but traversing the whole disk to find all files will be slow.
Does time machine ask the user to wait? Or does it keep a cache of the backups?
NethServer keeps a cache, using duc (the same tool to measure disk usage).
Yes, I saw that, I disabled it took twice the time needed for the backup itself.
I would simply read and display the folder on the disk. The only real issue doing so is searching for every copy (backup) of a given file. But in my experience, I used that function maybe 10 times in 10 years.
Os/x restore files or a full installation by simply copying the latest or other backup folder, then probably restores databases and others tricks like we do.
The ACL and extended attributes are kept by making the use of an Apple file system mandatory, OR by creating a “sparsebundle” monolithic file containing an HFS (Apple) filesystem on a non-Apple file system. That’s a clever and controlled solution.
The indexing is done (for searching) by the general file indexer (which indexes also the contents, on the fly), Spotlight.
Maybe we could use some Lucene indexer for such use but I believe that it is really not a priority
This is a nice idea but will it put additional stress on the backup process? Also you need to add the class to get the info and also another one to read the info.
As resource wise, will this prove its utility if it is integrated into the backup?
Don’t get me wrong, i just ask as a way to see the best approach.
My general feeling is that we don’t really need to create any index of any sort regarding backups. Just browse the files & folders tree on the backup disk, done.
I believe the way Duplicity stored the files on the disk made the indexing step mandatory. But it is not needed here.
on the other hand I guess that we can use the log file (if you want to have the files parsed and indexed)
Rsync can output the activity or even generate the listing in a file in a specified format, if I’m not mistaking.
This way you have the index files generated from the log. Easy to parse and use.
Even tar (or most archivers) can generate a listing of the files (including the paths) if needed.
