Hi @edoardo_spadoni , I beg your pardon. I know it’s alway me who’s moaning about DUC, but I’ll report it again, because I think it’s not a good thing to have a feature, that doesn’t do what it should do.
AFAIK DUC is your module.
/var/lib/urbackup/du -sh : 153 GB Difference again 150 GB
It seems. that DUC counts the backups twice and tripple. Maybe because of the way urbackup saves the incremental backups. If the urbackup grows enough, the reported diskusage will even exeed the real size of the disk.
I’m sorry to bother you again with this, but is it possble to solve this behaviour of DUC?
duc is a fun utility, maybe we should put it in de doc or readme about the command line usage…
Does the “duc ui” report something strange if you navigate to the /var/lib/urbackup directory with arrow keys?
It does show the size of files too, maybe we can figure out why it reports a wrong value here…
I didn’t notice something strange. But I’m at home on my tablet. Will play a bit tomorrow and check if I can figure out something.
Thanks for answers.
Till tomorrow.
I had a look at the code of duc at github an found the -H option for indexing. The manual states that this option tells duc to count hardlinked files only once.
When I use the -H option in nethserver-duc-index the reported disksize shrinks to the value of the one reported by du. (from 386,6 to 216,5 => du and dashboard report the same)
What do you think @giacomo ? Can we change this in source-file?
AFAIK only nethserver-restore-data depends on duc too. It builds it’s own (duc) database/index on another location and would not be effected by this change.
It works for me although used the more descriptive option --check-hard-links to make it more clear what it is about. According to the documentation (cc in the commit) it is the same.
IMHO all con’s and pro’s in mind, it is a usefull enhancement.
Or would it be better to add and db-prop for it and you have the possibility to choose? IF SO which default behavior would we favor?
Since it seems to make no diffreence if you have installed no hardlinking software, but it make a bif difference if you have, I’ll vote for making -H default.
It does matter on very large systems, because it makes indexing slower, but I don’t think, that those system are the main porpose for NS.
So, yes I’d make it default.
