NethServer Version: 7.4.1708
Module: OpenVPN
I have configured OpenVPN roadwarrior as follows;
And I have configured transparent proxy with web filtering;
And its works perfectly on the remote client
However, where I have a problem, it is in the IP allocation part, because according of the openvpn client, I should assign it the reserved IP configurated in the server, however it assignis a random one, so I can not assign the correct filter to the correct IP of the openvpn client, I need connect 8 clients, two without limits and the others blocked all.
I was created the firewall objects with the IP clients reserved
Sorry for my bad english.
