The subscription fragment does what is expected (at least in the developers mind ): it makes sure that only supported repositories are enabled. This safeguard has saved the life of tech support many times!
If you still want other repositories enabled, I think the solution suggested by @stephdl is the good one.
I think you can remove the two files and update from my repo, keep me in touch, the file should have moved to 45 and after the event my repo should be enabled
