Demoting a leader node, and adding it to another leader node
How could one, if possible, demote an existing LEader node to a worker node, and add it to another leader node?
or alternatively, adding the elader node to another leader node and demoting it to worker node?
Hi @oneitonitram
Basically this:
:slight_smile:
This one has 2 separate NS8 Servers that were deployed as separate clusters.
The aim now is to combine the 2 Leader nodes into a single cluster, Where one is demoted as the leader and made as a client node.
That will not work, according to @davidep …
Simply as they are not in the same cluster.
And merging data or users / groups from two different clusters is a no-go…
You can achieve the same effect with backup/restore of individual modules.
There is no Merging Data or anything, Just the Apps running on that other node.
That would be a heck amount of work if the Node has alot of Apps running etc.
when setting up a new NS8 instance, we are asked if we want the server to be leader or to join an existing cluster?node
WHat would prevent the server if setup as a Leader, From Being able to Join an existing cluster as a client node, and lose the privileges it has a leader node?
For example, both leaders can have a Unix user traefik1: there is an instance name conflict.
Wouldnt dropping it that traefik/ collapsing it in favour of the main one that becomes the leader work
