Does ddclient have a UI other than the basic settings that show up in the NS8 UI for it? My domain is registered through porkbun and the their api for my domain has both a public key and a secret key that has to be entered in the ddclient.conf script. Google AI says to enter those in the ddclient login and password (respectively) in the NS8 UI, and to enter porkbun.com for the FQDN of provider server field in the NS8 UI.
Am I entering this properly in the UI if my ddclient.conf script includes the following? I know porkbun says it doesn’t offer ddns and uses cloudflare for that, so I’m assuming the api keys are associated with that, meaning, porkbun takes care of the mapping with cloudflare and I shouldn’t have to do anything with a cloudflare account, should I?
Yes, I have that repo installed and enabled, which is where I got the ddclient app from. I was just wondering if there was a separate GUI for the app than just what’s in the NS8 UI for the ddclient configuration, that included more parameters perhaps? I was also hoping someone could tell me if I entered the information correctly, meaning, I entered what was expected for each field? Thanks.
As I said above, Google AI said to place the public key as username in the Nethserver 8 UI for ddclient, then place the secret key as the password, but doing it this way shows up in the ddclient.conf script (of the ddclient1 instance) as
rather than the pic above, which is why I was searching for confirmation that the Google AI suggestion was the proper way. If I am to do it like the picture shows, I have to physically edit the script rather than use the UI. However, if I make a change later in the UI and save it, it will delete the keys from the script.
