CrowdSec does not start
Let’s check which crowdsec services are there:
systemctl | grep crowdsec
Try to restart the crowdsec2 service if it exists:
systemctl restart crowdsec2
agent@crowdsec2.service loaded active running Rootfull crowdsec2 agent
crowdsec2-firewall-bouncer.service loaded activating auto-re start crowdsec-firewall-bouncer server
● crowdsec2.service loaded failed failed crowdsec server
crowdsec2-upgrade-hub.timer loaded active waiting Timer of crowdsec hub update
After restart of crowdsec2 service everything looks good. Now i will do a reboot…
And the problem is there again.
Error: no container with name or ID “crowdsec2” found: no such container
Sorry, I’m out of ideas for now…maybe you could setup a cronjob that restarts the service if not running.
Thank you very much, Markus. I will see what is to do. May be th best way is a fresh installation of NS8 and to install the CrowdSec module at first.
Regards…
Uwe
Same problem with a brandnew installation of NS8 and only CrowdSec.
Who is supposed to understand that?
I have no issues on Rocky based nodes, what OS are you running on this specific node?
I use also Rocky. Fresh and virgin…
that you have reproduced twice the same issue. what is the hypervisor and what is the OS, what version of that OS you installed
I have installed on real sheet metal. Rocky 9.3 with Etcher on a USB stick and booted and installed from there. This also works and takes just under eight minutes. Then I installed NS8 as described in the documentation. Also works wonderfully. Of course I updated Rocky beforehand. And then just install CrowdSec and the trouble begins…
journalctl can give us the full journal of event, without it we cannot do something
Not possible in this moment. Server is in fresh installation modus.
New test with Alma Linux 9.3 and everthing is ok. CrowdSec is working.
I am wondering something @transocean We know that crowdsec upstream has implemented a ratelimit that I have often reached by installing module in my home lab, maybe you got the same hit
Symptom is that crowdsec fails to start because you cannot download the hub
@stephdl,
i have now gone one step further and do not believe that this has anything to do with the different operating systems under the NS 8. After searching in the server’s bios, I found a second active network card there. I deactivated it and tried again with Rocky 9.3. And what can I say? CrowdSec is now working. I will now continue with the installation of Mail and SoGo and see how it goes.
if i start the Server i got this information… do i have to pay attention? Because from the Cockpit everything is started only the Crowdsec Hub is not
it is a systemd timer set to run each 15 days, like named to upgrade the hub (repository) of crowdsec for collections
so anything should work?
few minutes each 15 days :stuck_out_tongue:
okay, guess that´s enough for me :rofl:
