NethServer Version: 7.6.1810
Module: Cockpit
I am following tutorial to create a module in cockpit. When i launch make-rpms i obtain this log. Can anyone help me?
make-rpms nethserver-mymodule.spec
prep-sources [INFO] source0 git archive: nethserver-mymodule-0.0.0.tar.gz
INFO: mock.py version 1.4.16 starting (python version = 3.6.8)...
Start: init plugins
INFO: selinux disabled
Finish: init plugins
Start: run
INFO: Start(nethserver-mymodule.spec) Config(nethserver-7-x86_64)
Start: clean chroot
Finish: clean chroot
Start: chroot init
INFO: calling preinit hooks
INFO: enabled root cache
Start: unpacking root cache
Finish: unpacking root cache
INFO: enabled yum cache
Start: cleaning yum metadata
Finish: cleaning yum metadata
INFO: enabled HW Info plugin
Mock Version: 1.4.16
INFO: Mock Version: 1.4.16
Start: yum update
Failed to set locale, defaulting to C
Finish: yum update
Finish: chroot init
Start: buildsrpm
Start: rpmbuild -bs
Failed to create directory /var/lib/mock/nethserver-7-x86_64/root//sys/fs/selinux: Read-only file system
Building target platforms: x86_64
Building for target x86_64
Wrote: /builddir/build/SRPMS/nethserver-mymodule-0.0.0-1.ns7.src.rpm
Finish: rpmbuild -bs
Finish: buildsrpm
INFO: Done(nethserver-mymodule.spec) Config(nethserver-7-x86_64) 2 minutes 1 seconds
INFO: Results and/or logs in: .
INFO: Cleaning up build root ('cleanup_on_success=True')
Start: clean chroot
Finish: run
Start: init plugins
Start: run
INFO: Start(nethserver-mymodule-0.0.0-1.ns7.src.rpm) Config(nethserver-7-x86_64)
Start: clean chroot
Start: chroot init
Start: yum update
Finish: yum update
Finish: chroot init
Start: build phase for nethserver-mymodule-0.0.0-1.ns7.src.rpm
Start: build setup for nethserver-mymodule-0.0.0-1.ns7.src.rpm
Getting requirements for nethserver-mymodule-0.0.0-1.ns7.src
--> nethserver-devtools-1.2.1-1.ns7.noarch
Package Arch Version Repository Size
Installing:
nethserver-devtools noarch 1.2.1-1.ns7 nethserver-base 21 k
Installing for dependencies:
freetype x86_64 2.8-12.el7_6.1 updates 380 k
jbigkit-libs x86_64 2.0-11.el7 base 46 k
libjpeg-turbo x86_64 1.2.90-6.el7 base 134 k
libpng x86_64 2:1.5.13-7.el7_2 base 213 k
libtiff x86_64 4.0.3-27.el7_3 base 170 k
libwebp x86_64 0.3.0-7.el7 base 170 k
python-docutils noarch 0.11-0.3.20130715svn7687.el7 base 1.5 M
python-pillow x86_64 2.0.0-19.gitd1c6db8.el7 base 438 k
Transaction Summary
Install 1 Package (+8 Dependent packages)
Total size: 3.1 M
Installed size: 10 M
Installed:
nethserver-devtools.noarch 0:1.2.1-1.ns7
Dependency Installed:
freetype.x86_64 0:2.8-12.el7_6.1 jbigkit-libs.x86_64 0:2.0-11.el7 libjpeg-turbo.x86_64 0:1.2.90-6.el7 libpng.x86_64 2:1.5.13-7.el7_2 libtiff.x86_64 0:4.0.3-27.el7_3 libwebp.x86_64 0:0.3.0-7.el7
python-docutils.noarch 0:0.11-0.3.20130715svn7687.el7 python-pillow.x86_64 0:2.0.0-19.gitd1c6db8.el7
Finish: build setup for nethserver-mymodule-0.0.0-1.ns7.src.rpm
Start: rpmbuild nethserver-mymodule-0.0.0-1.ns7.src.rpm
Start: Outputting list of installed packages
Finish: Outputting list of installed packages
Executing(%prep): /bin/sh -e /var/tmp/rpm-tmp.httTio
+ umask 022
+ cd /builddir/build/BUILD
+ rm -rf nethserver-mymodule-0.0.0
+ /usr/bin/gzip -dc /builddir/build/SOURCES/nethserver-mymodule-0.0.0.tar.gz
+ /usr/bin/tar -xvvf -
drwxrwxr-x root/root 0 2019-03-19 11:54 nethserver-mymodule-0.0.0/
-rw-rw-r-- root/root 18046 2019-03-19 11:54 nethserver-mymodule-0.0.0/COPYING
-rw-rw-r-- root/root 119 2019-03-19 11:54 nethserver-mymodule-0.0.0/README.md
drwxrwxr-x root/root 0 2019-03-19 11:54 nethserver-mymodule-0.0.0/api/
-rw-rw-r-- root/root 0 2019-03-19 11:54 nethserver-mymodule-0.0.0/api/read
-rw-rw-r-- root/root 0 2019-03-19 11:54 nethserver-mymodule-0.0.0/api/update
-rw-rw-r-- root/root 0 2019-03-19 11:54 nethserver-mymodule-0.0.0/api/validate
-rw-rw-r-- root/root 1215 2019-03-19 11:54 nethserver-mymodule-0.0.0/createlinks
-rw-rw-r-- root/root 832 2019-03-19 11:54 nethserver-mymodule-0.0.0/nethserver-cockpit-empty.json
-rw-rw-r-- root/root 1106 2019-03-19 11:54 nethserver-mymodule-0.0.0/nethserver-cockpit-empty.spec
-rwxrwxr-x root/root 146 2019-03-19 11:54 nethserver-mymodule-0.0.0/prep-sources
drwxrwxr-x root/root 0 2019-03-19 11:54 nethserver-mymodule-0.0.0/ui/
drwxrwxr-x root/root 0 2019-03-19 11:54 nethserver-mymodule-0.0.0/ui/css/
-rw-rw-r-- root/root 0 2019-03-19 11:54 nethserver-mymodule-0.0.0/ui/css/style.css
drwxrwxr-x root/root 0 2019-03-19 11:54 nethserver-mymodule-0.0.0/ui/i18n/
-rw-rw-r-- root/root 98 2019-03-19 11:54 nethserver-mymodule-0.0.0/ui/i18n/language.json
-rw-rw-r-- root/root 2549 2019-03-19 11:54 nethserver-mymodule-0.0.0/ui/index.html
drwxrwxr-x root/root 0 2019-03-19 11:54 nethserver-mymodule-0.0.0/ui/js/
-rw-rw-r-- root/root 6254 2019-03-19 11:54 nethserver-mymodule-0.0.0/ui/js/app.js
drwxrwxr-x root/root 0 2019-03-19 11:54 nethserver-mymodule-0.0.0/ui/js/lib/
-rw-rw-r-- root/root 27206 2019-03-19 11:54 nethserver-mymodule-0.0.0/ui/js/lib/sammy.js
-rw-rw-r-- root/root 6134 2019-03-19 11:54 nethserver-mymodule-0.0.0/ui/js/lib/sammy.template.js
-rw-rw-r-- root/root 8626 2019-03-19 11:54 nethserver-mymodule-0.0.0/ui/logo.png
-rw-rw-r-- root/root 20 2019-03-19 11:54 nethserver-mymodule-0.0.0/ui/manifest.json
-rw-rw-r-- root/root 45 2019-03-19 11:54 nethserver-mymodule-0.0.0/ui/override.json
drwxrwxr-x root/root 0 2019-03-19 11:54 nethserver-mymodule-0.0.0/ui/views/
-rw-rw-r-- root/root 23 2019-03-19 11:54 nethserver-mymodule-0.0.0/ui/views/about.html
-rw-rw-r-- root/root 28 2019-03-19 11:54 nethserver-mymodule-0.0.0/ui/views/dashboard.html
-rw-rw-r-- root/root 24 2019-03-19 11:54 nethserver-mymodule-0.0.0/ui/views/item1.html
-rw-rw-r-- root/root 22 2019-03-19 11:54 nethserver-mymodule-0.0.0/ui/views/logs.html
+ STATUS=0
+ '[' 0 -ne 0 ']'
+ cd nethserver-mymodule-0.0.0
+ /usr/bin/chmod -Rf a+rX,u+w,g-w,o-w .
+ exit 0
Executing(%build): /bin/sh -e /var/tmp/rpm-tmp.c8kAp4
+ umask 022
+ /usr/bin/make -f /usr/share/nethserver-devtools/docs.mk
make: Nothing to be done for `all'.
+ perl createlinks
+ exit 0
Executing(%install): /bin/sh -e /var/tmp/rpm-tmp.F0RjEK
+ umask 022
+ '[' /builddir/build/BUILDROOT/nethserver-mymodule-0.0.0-1.ns7.x86_64 '!=' / ']'
+ rm -rf /builddir/build/BUILDROOT/nethserver-mymodule-0.0.0-1.ns7.x86_64
++ dirname /builddir/build/BUILDROOT/nethserver-mymodule-0.0.0-1.ns7.x86_64
+ mkdir -p /builddir/build/BUILDROOT
+ mkdir /builddir/build/BUILDROOT/nethserver-mymodule-0.0.0-1.ns7.x86_64
+ mkdir -p /builddir/build/BUILDROOT/nethserver-mymodule-0.0.0-1.ns7.x86_64/usr/share/cockpit/nethserver-mymodule/
+ mkdir -p /builddir/build/BUILDROOT/nethserver-mymodule-0.0.0-1.ns7.x86_64/usr/share/cockpit/nethserver/applications/
+ mkdir -p /builddir/build/BUILDROOT/nethserver-mymodule-0.0.0-1.ns7.x86_64/usr/libexec/nethserver/api/nethserver-mymodule/
+ tar xvf /builddir/build/SOURCES/nethserver-mymodule.tar.gz -C /builddir/build/BUILDROOT/nethserver-mymodule-0.0.0-1.ns7.x86_64/usr/share/cockpit/nethserver-mymodule/
css/
css/style.css
i18n/
i18n/language.json
index.html
js/
js/app.js
js/lib/
js/lib/sammy.js
manifest.json
override.json
views/
views/about.html
views/item1.html
views/logs.html
+ cp -a nethserver-mymodule.json /builddir/build/BUILDROOT/nethserver-mymodule-0.0.0-1.ns7.x86_64/usr/share/cockpit/nethserver/applications/
cp: cannot stat 'nethserver-mymodule.json': No such file or directory
RPM build errors:
error: Bad exit status from /var/tmp/rpm-tmp.F0RjEK (%install)
ERROR: Exception(nethserver-mymodule-0.0.0-1.ns7.src.rpm) Config(nethserver-7-x86_64) 2 minutes 11 seconds
INFO: Cleaning up build root ('cleanup_on_failure=True')
Start: clean chroot
ERROR: Command failed:
# /usr/bin/systemd-nspawn -q -M 6940fd33f619438d8268102f777996ae -D /var/lib/mock/nethserver-7-x86_64/root -a --capability=cap_ipc_lock --bind=/tmp/mock-resolv.g7462uu7:/etc/resolv.conf --setenv=TERM=vt100 --setenv=SHELL=/bin/bash --setenv=HOME=/builddir --setenv=HOSTNAME=mock --setenv=PATH=/usr/bin:/bin:/usr/sbin:/sbin --setenv=PROMPT_COMMAND=printf "\033]0;<mock-chroot>\007" --setenv=PS1=<mock-chroot> \s-\v\$ --setenv=LANG=C -u mockbuild bash --login -c /usr/bin/rpmbuild -bb --target x86_64 --nodeps /builddir/build/SPECS/nethserver-mymodule.spec
