Hello everybody . I would like to know how to create a folder where you can insert small programs in php and be processed by the server as for example; http://myserver.ddns.net/program. I don’t want to create virtual hosts but just use the existing fqdn name with the addition of the / folder. I saw that in etc / httpd / conf.d / *** there are links to / usr / share / folder.
an example is the installation of glpi or wordpress betting on the cards in / usr / share / ****.
Thank you
create your php script inside /var/www/html/
for your folder it is /var/www/html/folderName
Yes, thanks Stephane, I knew that the publication of a program or other must always be copied to / var / www / html / folder. I wonder why the same applications like wordpress or glpi (which I have on my server) are in / usr / share / ***. Maybe I had asked the question wrong. Thank you
you have default place for software with linux
/var/lib/
for data
/usr/share/
for applications
/etc/
for settings
etc…
