What is the best way to connect a larger network or a “cloud” of wifi access points (eg zyxel wac6500) or the zyxel hospitality solution (Unified Access Gateway, uag2100) to the nethserver?
Or is there some better alternatives?
Already some success stories?
Hi, here is http://dev.nethserver.org/projects/nethserver/repository/coova-chilli
You can connect it to the green LAN adapter and use it as whatever AP or I didn’t quite understand your question
He needs somth like Ap management Hot Spot , so Coova-chilli or similar captivate portal
