Confused about editions
I have downloaded and installed Nethserver however have a few questions.
  1. I have updated my system however the website indicates I require a subscription for updates?
  2. Is there an enterprise edition as opposed to community edition?
    I can only see one download option available.
  3. What is the recommended groupware solution?
    The website indicated SoGo. http://www.nethserver.org/learn-more/ however the docs state SoGo is not supported in the enterprise edition? http://docs.nethserver.org/en/v7/sogo.html
Thanks
No it doesn’t. You need a subscription only if you want a paid support. More info to come next days.
Yes, it’s almost the same (it just contains a couple of extra modules) and it can be downloaded only if you became a Nethesis reseller. This is why the community proposed the subscription above.
If you’re interested, I can give you commercial contacts in a private message.
If you use the community version you can choose whatever you want between SOGo and WebTop (or even Horde!). The community is very quick on giving support and fixing issues!
By the way, if you want to buy the Enterprise version, only WebTop is supported there :slight_smile:
If you need more info, just ask!
Yes, I am interested in becoming a reseller. Can you pm me the details.
Hi Henry,
thanks for being here.
Subscription is only the way to go! You can have a preview here: http://www.nethserver.org/subscription/
Tomorrow IS THE DAY, please hold on just for a few hours :slight_smile:
If you plan to subscribe multiple installations, when your application reaches volume scale, you’ll automatically get volume pricing with a discount on all renewals and new subscriptions. No negotiation necessary.
Subscription will be offered on the NethServer community edition, no multiple editions to handle.
SOGo is not supported by the Subscription
Is it more clear now?
