Conflict between WebTop and SoGo?
NethServer Version: 7.5
Module: sogo, webtop
As I’ve mentioned before, I mainly run my Neth box for my family. When I reasonably can, I like to give options. So there are five packages for Neth that do webmail: Roundcube, Rainloop, Horde, WebTop, and Sogo. Right now I have Roundcube and Horde installed, and will probably play with Rainloop shortly. I’d be glad to go ahead and install Sogo and WebTop as well, but I see that they both do ActiveSync. Is there going to be any conflict between these? Or can I have them both installed without causing any problems? Any gotchas I should be aware of?
You need to decide which service will provide the Active Sync protocol.
See http://docs.nethserver.org/en/v7/webtop5.html#webtop-vs-sogo
yes you do, however when we (i) wrote the redirects web-top has preference…
Was never tested as webtop 5 was in full development back then…
  if ((($sogod{'ActiveSync'} || '') eq 'enabled') && (($webtop{'ActiveSync'} || 'disabled') eq 'disabled')){
     $OUT .= <<EOF
# Sogo ActiveSync is enabled
same for DAV
if ((($sogod{'Dav'} || '') eq 'enabled') && (($webtop{'Dav'} || 'disabled') eq 'disabled')){
          $OUT.= "RewriteRule ^/^(cal|card|dav)\$               https://%{HTTP_HOST}/SOGo/dav [R=301,L] \n";
          $OUT.= "RewriteRule ^/.well-known/^(caldav|carddav)\$ https://%{HTTP_HOST}/SOGo/dav [R=301,L] \n\n\n";
You could be the guinea-pig and test if it works? :roll_eyes::smirk:
I’m not personally interested in ActiveSync at all, as long as the one system doesn’t break the other. I guess I’ll try it with the defaults, and if something starts to look broken, probably disable ActiveSync in both apps.
BTW, there’s a bug on the WebTop doc page in the section where it tells you how to configure Google and Dropbox integration. It says (in two places) to run
su - postgres -c "psql webtop"
In reality, you need to run:
su - postgres -c "psql webtop5"
Well, I thought I’d install both, but SOGo doesn’t appear in the software center, and yum install nethserver-sogo doesn’t work either.
Sogo is in nethforge, check if the repo is enabled, you could also clean the cache
Does that mean it isn’t production-ready? Or only that I won’t get it (without manually enabling the nethforge repo) if I have a subscription on my server?
@dan excuses for this hijack of your toppic
@giacomo as you noticed , i’ve got some time left, sorry for asking so much attention
looking at this
this
Above statement about {Card Cal}-dav is false, as WebTop5-webdav is not {dis en}abled with a e-smithdb-prop. Just sharing en insight here :grinning:
@webtop_team
Are you saying that SOGo implements the same configuration for WebDav?
I didn’t check it, to be honest.
@alefattorini could you add @Amygos to webtopm_team?
Sogo treats (e-smith props) ActiveSync and Dav in the same manner.
IMHO it’s a nice feature be able to remove all rewrite rules to (what-ever) web-service; Just a matter of preference: close the most in front possible door.
Have to live up to my words here!
seems that the subscription broke something, normally nethforge is enabled per default since years, try to add it manually --enablerepo=nethforge
I ping here @davidep
Define “(not) production-ready”
I am running SOGo for about half year now on NethServer. (before that I ran SOGO2.x on Linuxschools) and it hasn’t failed me yet.
Although I must say, I barely use the web interface. Most use of my mailserver is through Thunderbird.
Nethesis does not sell support for packages in NethForge, so #subscription installations do not have NethForge enabled by default.
@dan if you have #subscription and want to re-enable nethforge for SOGo refer to
http://docs.nethserver.org/en/v7/subscription.html
EDIT: the issue seems to have been fixed
I am currently using sogo on a production environment, before setting up the environment I had staging environment for a bout two weeks, sogo and webtop did not do so well, I have multiple conflicts, which in some cases caused me to have to re-build the whole installation. so I would not install the two at the same time, if you have had luck let me know, I try again on one of my staging servers.
What kind of conflicts, can you detail them and provide logs please
I will rebuild the server and replicate the process, then share what I was experiencing
Done, sorry for the late reply :slight_smile:
as promised, I tried rebuilding the server and replicating the steps that I followed initially to see the erro, but its seems like there is an update that fixed the error.
Initially, I had tried more than three times with the same error.
