BOUUUUUUUUUUUU I cannot reproduce, it works as expected
I will detail my procedure later
could you please test my new version of dokuwiki
yum install http://mirror.de-labrusse.fr/NethDev/nethserver-dokuwiki/nethserver-dokuwiki-1.2.4-1.ns7.sdl.noarch.rpm
you should be aware also of a bug in the vhost, please check https://github.com/NethServer/dev/issues/5515
for the moment, please remove nextcloud, I need to check also on it.
Issue done for nextcloud
so,
good news: I get it working. ![]()
My mistake was:
So the instructions (for now!) are:
If I may wish something:
@stephdl : should I try (= is it then necessary?) the new rpm?
@all: thanks for the support in any case:wink:
With the rpm I did it is not necessary, we have had an issue I solved
Do you still have an issue with nextcloud ???
yes you could try my rpm please, and report…before I break 1 000 000 servers
Upps. I didn’t know that you made an rpm for joomla…
With the instructions I wrote above, nextcloud works fine from the virtualhost, but only if the conf file has been renamed.
I tried your rpm (= simply updating dokuwiki) and… I can see no difference: the conf file is still zzz_dokuwiki.conf, dokuwiki works from the virtualhost, dokuwiki lets access to www.domain.tld for Joomla etc…
=> what have you modified? Where is the difference?
for dokuwiki I did a new rpm you can download from my repository
for next-cloud I just did an issue in GH, but what you said drive me to do something
@davidep @giacomo what do you think of Apache Virtualhost Collision · Issue #5517 · NethServer/dev · GitHub
OK i can release ![]()
confirmed, nextcloud.conf is caught as the default vhost and take all apache requests
*:80 is a NameVirtualHost
default server wordpress.de-labrusse.fr (/etc/httpd/conf.d/nextcloud.conf:1)
port 80 namevhost wordpress.de-labrusse.fr (/etc/httpd/conf.d/nextcloud.conf:1)
*:443 is a NameVirtualHost
default server wordpress.de-labrusse.fr (/etc/httpd/conf.d/nextcloud.conf:6)
port 443 namevhost wordpress.de-labrusse.fr (/etc/httpd/conf.d/nextcloud.conf:6)
