Collectd not showing
NethServer Version: 7.9.2009
Module: Collectd
I can’t really say I know when it happened however, I noticed there is no way for me to access the collectd graphs anymore, the service exists and it is running with no errors in any of the logs from what I can find, however it doesn’t show up under the “Applications” anymore. Is there anyway to try and fix the issue or does someone know the URL I could try and access it by?
I have tried reinstalling it but still get the same result.
My guess would be an incorrectly configured config (I havn’t knowingly changed any of them manually) or there is a package missing but I would have thought a reinstall of collectd would have reinstalled any missing packages. I’m still kind of new to anything outside of GUI.
Current installed modules
Awstats
Crontab Manager
Dynamic DNS
Fail2Ban
File Server
Firewall
PhpMyAdmin
5.5.68-MariaDB
10.3.27-MariaDB
Report
Restore Data
WebServer
PHP 5.4
PHP 7.3
PHP 8.0
Looking a your installed modules, I think you need to install the Statistics module in the software- center
Thank you, I must have overlooked it or something … :rofl: :rofl: :rofl:
