@giacomo thanks for explaining
The new implementation is read for testing thanks to @andre8244!
Check it out:
I hope we have meet all your expectations @flatspin @danb35 @pike @federico.ballarini @carsten !
Nice job!
Big thanks to @andre8244!! Really well done.
Now there is a great overview over all services.
Missing local rulesā¦
# rpm -qa nethserver-fir*
nethserver-firewall-base-ui-3.8.1-1.ns7.noarch
nethserver-firewall-base-3.8.1-1.ns7.noarch
No further updates currently available (at time of post).
No testing repositories enabledā¦
Already fixed Thanks to @andre8244
Ok, i can thank this guy. But i still cannot see any difference. Thereforeā¦
New updated package has to be deployed for update?
kudos to @andre8244 tnx! installation is ok also on armhfp and aarch64
@pike packages are in testing, you should add āāenablerepo=nethserver-testingā to yum command
Ok, iām gonna wait the release.
You should have:
- nethserver-firewall-base-3.8.2-1.ns7.noarch.rpm
- nethserver-firewall-base-ui-3.8.2-1.ns7.noarch.rpm
- nethserver-cockpit-1.3.14-1.ns7.noarch.rpm
The mirror will be in syn soon, otherwise you can access directly the master mirror and grab latest release
Here there areā¦
nethserver-firewall-base-3.8.3-1.ns7.noarch
nethserver-firewall-base-ui-3.8.3-1.ns7.noarch
I dont see the cockpit services and the port 9090 in the new services list. I see only the old interface with port 980. Why?
This seems to me like either it was not included on the GUI or it is being defined somewhere else. You are right in that I also cannot find anything defining Cockpit in the services or local firewall rules. This may be a bug but Iād say we need input from devs.
Because cockpit usually is not running and itās started using systemd socket activation.
Rules for the firewall are hard coded: nethserver-cockpit/root/etc/e-smith/templates/etc/shorewall/rules/70cockpit at master Ā· NethServer/nethserver-cockpit Ā· GitHub
