Just setup a fresh install and completed updates, after this I started tackling network setup when I attempted to set the green interface to Static from DHCP using Cockpit. This fails and just reloads the “Configure physical interface” screen when selecting “Configure”.
The old server manager successfully performs this operation and cockpit can successfully perform the reverse of this operation (setting the interface from Static to DHCP)
This issue persists even when filling in all fields including the optional “Label” for the interface.
Is there anyone else who can confirm this? I have also not replicated/tested this on other interfaces (RED, BLUE or ORANGE)
