I previously installed Nethserver with a dummy LAN interface and I have now installed a second physical LAN interface.
I would like to know how to remove the dummy interface and configure the new physical LAN interface instead. Can this be solved without data loss or need to be reinstalled?
@mrmarkuz
Thank you for your answer. I will look into it shortly, but unfortunately I got stuck with another problem.
I want to put Nethserver on a separate subnet behind my router but unfortunately there is a problem setting it up. I have to fix this first, otherwise I won’t be able to access Nethserver.
@mrmarkuz
Thank you for your advice. The br0 bridge and dummy interface network was the same as the samba AD network so the solution was simple.
I studied the network reconfiguration in the GUI and managed to solve it. It is important to first add the physical interface to the br0 bridge, and after this is done, remove the dummy interface from the br0 bridge by reconfiguring the network in a separate step. The Nethserver is then available from the new green interface and everything works.
