Today i tried to install `CentOS Web Panel -web hosting panel- on NethServer 6.6 (Both Work with CentOS 6)
but after the installation finished i’m no longer able to access NethServer Management interface.
Is there anything I can do to use the two of them together??
From what I read CWP compile on the fly php and apache, not sure that both are compatible. Moreover they announce that there is no uninstaller of their software, you need to reinstall from scratch if you have issues. In clear they assume that you have only CWP on the server
