Good evening,
I receive emails but nothing is sent, or do I have to search, or do I have to reinstall everything?
Thanks for your help.
Salut Frederic
I think it would be best to open a new Post, specific tp your problem!
Choose an appropriate title, like âproblem sending mails, incoming worksââŠ
Bonsoir Andy,
Merci de me repondre ,
I will try to open a request for this problem, thanks to you again, but I donât have the ability with nethserver so not easy for me.
Frederic
Salut Frederic
Je pense, avec un titre nouveau, câest plus facile pour aider et plus facile pour un autre, qui a la mĂšme problĂšme, de trouve le solutionâŠ
Mes deux centimes
English:
I think with a new title, itâs easier to help you, but also for others who might have the same problem, to find a solution.
Hi Andy,
Frederic original problem had the same output: ââŠrspamd_map_dns_callback: cannot resolveâŠâ
After doing what strauch did:
then, it was possible to receive mail but impossible to send one.
I am sure Frederic can open a new post but I think the problem is still related to this original post.
The solution might be something with the router:
Michel-André
