Всем привет.
Прошу помощи. Не могу зайти в настройки. Скорей всего ограничил доступ к модулям. Как можно восстановить доступ пользователю admin?
I took the liberty to translate your message in English:
Hello.
I ask for help. I can not enter the settings. Most likely I restricted access to the modules. How can I restore access to the admin user?
Maybe our FreePBX users and devs can help you further. @Stll0, @mrmarkuz
Would you please post in English next time? Most of our members don’t understand Russian. @Nas to the rescue?
If your English is not good enough to post in English, you can always use Google translate. (that’s how I translated your text)
I hope you enjoy NethServer and our community.
Thanks @robb for translation!
I have another Christmas program today and can’t have look now but I’d copy the admin password from the DB of a working installation to the DB of the failed freepbx…and maybe check rights in /var/www/html/freepbx…
I could reproduce your case when I put the modules to “not selected” under admin access:
You could set it to access all modules again via mysql on command line:
echo "update ampusers SET sections = '*' where username = 'YOURADMINUSER';" | mysql asterisk
@Tesla
https://wiki.freepbx.org/display/L1/amportal+commands can be useful.
update ampusers SET sections = '*' where username = 'admin';
For mysql password look in the file /etc/amportal.conf
Hey. The query was executed without errors, but it did not work. Here’s the log:
authz_core:error] [pid 16520] [client 127.0.0.1:33838] AH01630: client
denied by server configuration: /var/www/html/freepbx/admin/modules/index.htm```
Access is not clear, where to dig is not very clear. File permissions checked, the script runs without errors.
I read on the forum that it seems to remove completely FreePBX from NethServer. So
Is it? Or what are left?
amportal a dbug
показывай
Please wait…
!!!amportal is depreciated. Please use fwconsole!!!
forwarding all commands to ‘fwconsole’
This is an apache conf error, maybe a disturbing .htaccess file or some misconfigured apache .conf file. In my installation, there is no file /var/www/html/freepbx/admin/modules/index.html.
Are other webapplications still working?
Are there any errors in in the log files /var/log/asterisk/freepbx.log or /var/log/messages?
I saw you updated your freepbx, maybe somethings gone wrong with the updates. I’ll try to reproduce asap.
Found some freepbx forum entries with no real solution:
Thank you for your assistance. It worked! Just rebooted the server. Without this, apparently, did not apply the settings after correcting the errors.
