Upload certificate may not cover al the options (ie Request Let's Eencrypt certificate ) can’t think of a better text … any suggestions? cc// @giacomo@edoardo_spadoni
I don’t like it either, but it’s a design pattern from Patternfly so we tried to stick on it.
I have 2 different proposal:
split the button into 3 different elements
keep the same stile but expose “Request Let’s Encrypt certitificate” as default action: nowadays usage of LE is much more common than uploading a custom cert
As-long as it is on the list of possible improvements
All software interfaces have their quirks. Once you know were to find “it” it isn’t an issue for you any more. That’s why experiences of new users is valuable to keep on improving nethserver.
