stephdl
(Stéphane de Labrusse)
February 7, 2020, 6:37pm
21
Hey Franck thank for your input, I read your link and yes MariaDB is no more the way to go.
This will give use some work for the howto because the postgresql DB are not saved automatically by our server, but it is not a blocking point
Do you have some experience with BareOS and NethServer to share, could you advice to make a module
stephdl
February 7, 2020, 7:29pm
22
I guess that we had the visit of Frank Kohler
Welcome here
stephdl
April 5, 2020, 7:38pm
23
Hello @Frank , we have now a nethserver-bareos to test, could you comment please ?
Frank
(Frank)
April 28, 2021, 10:45am
24
Hi Stéphane and all,
apologies for not replying earlier trying to follow all communities as best as I can.
Thank you for investing your time to create and test Bareos within Nethserver. I hope it will encourage more users to try out Bareos. Eager to hear and learn from your experiences to make Bareos better.
fausp
(fpausp)
April 28, 2021, 8:25pm
25
Tried to install it:
[root@srv2 ~]# yum install nethserver-bareos --enablerepo=stephdl
* ce-base: mirrors.prometeus.net
* ce-extras: mirrors.prometeus.net
* ce-sclo-rh: mirrors.prometeus.net
* ce-sclo-sclo: mirrors.prometeus.net
* ce-updates: mirrors.prometeus.net
* epel: mirror.nextlayer.at
* nethforge: mirror.alpix.eu
* nethserver-base: mirror.alpix.eu
* nethserver-updates: mirror.alpix.eu
* stephdl: stephdl.dargels.de
Resolving Dependencies
--> Running transaction check
---> Package nethserver-bareos.noarch 0:0.0.10-2.ns7.sdl will be installed
--> Processing Dependency: nethserver-postgresql12 for package: nethserver-bareos-0.0.10-2.ns7.sdl.noarch
--> Processing Dependency: bareos-webui for package: nethserver-bareos-0.0.10-2.ns7.sdl.noarch
--> Processing Dependency: bareos-database-postgresql for package: nethserver-bareos-0.0.10-2.ns7.sdl.noarch
--> Processing Dependency: bareos for package: nethserver-bareos-0.0.10-2.ns7.sdl.noarch
---> Package nethserver-postgresql12.noarch 0:1.0.0-1.ns7 will be installed
--> Processing Dependency: rh-postgresql12 for package: nethserver-postgresql12-1.0.0-1.ns7.noarch
---> Package rh-postgresql12.x86_64 0:3.4-1.el7 will be installed
--> Processing Dependency: rh-postgresql12-runtime for package: rh-postgresql12-3.4-1.el7.x86_64
--> Processing Dependency: rh-postgresql12-postgresql-server for package: rh-postgresql12-3.4-1.el7.x86_64
---> Package rh-postgresql12-postgresql-server.x86_64 0:12.5-1.el7 will be installed
--> Processing Dependency: rh-postgresql12-postgresql(x86-64) = 12.5-1.el7 for package: rh-postgresql12-postgresql-server-12.5-1.el7.x86_64
--> Processing Dependency: rh-postgresql12-postgresql-libs(x86-64) = 12.5-1.el7 for package: rh-postgresql12-postgresql-server-12.5-1.el7.x86_64
--> Processing Dependency: libpq.so.rh-postgresql12-5()(64bit) for package: rh-postgresql12-postgresql-server-12.5-1.el7.x86_64
---> Package rh-postgresql12-runtime.x86_64 0:3.4-1.el7 will be installed
---> Package rh-postgresql12-postgresql.x86_64 0:12.5-1.el7 will be installed
---> Package rh-postgresql12-postgresql-libs.x86_64 0:12.5-1.el7 will be installed
Error: Package: nethserver-bareos-0.0.10-2.ns7.sdl.noarch (stephdl)
Requires: bareos-database-postgresql
Requires: bareos
Requires: bareos-webui
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
mrmarkuz
(Markus Neuberger)
April 28, 2021, 8:53pm
26
It seems the bareos repo is missing:
https://wiki.nethserver.org/doku.php?id=bareos#installation
Maybe you just need to enable it
yum install nethserver-bareos --enablerepo=stephdl,bareos
fausp
(fpausp)
April 29, 2021, 5:44am
27
Yes, Installation went through and Version 19.2.7 has been installed… I was able to login with the admin user as described in the wiki…
