NethServer Version: 7.6.1810 Module: BackupPC from Stephdl wiki page
Hi all,
My last testing before making the switch to NethServer.
With BackupPC and SME, you specify the User Commands: DumpPreUserCmd and DumpPostUserCmd - /sbin/e-smith/signal-event pre-backup and /sbin/e-smith/signal-event post-backup.
SME server uses the pre-backup command to dump the DBs so they can be backup.
NethServer has the following command: post-backup-config, post-backup-data, post-restore-config, post-restore-data, pre-backup-config, pre-backup-data, pre-restore-config, and pre-restore-data.
Which ones are equivalent to the SME server’ones?
Do I have to use the ones for data and config?
Also, is there a special command with LDAP to backup and restore it?
It looks like everything is working fine now with BackupPC-4.3.0.
I wrote a documentation in French on how to backup/restore from a NethServer-7.6.1810 including a WordPress web site to a freshly installed server to make a clone of SOURCE server to DESTINATION server.
