Hi there pagaille, is posible to ask You the command to configure a USB external disk for a backup, at the end of the year I have the disks to probe this new feature, but I have all the weekend trying to configure the drive for backup and is not posible.
Hey giacomo, the cockpit was the answer for my problem Amazing job, nethserver 8 will be the top server to administrate, thanks , now is to check an error to edit the backup configuration.
@pagaille, thanks for the answer but the cockpit didit for me.
I need to rotate the hardrives every week (one drive is connected the other is in a bank locker), also i need to backup only 2 two days not 30d with rsync, I have to do it manualy but is not clear how to do it.
Uncaught TypeError: b.props.NotifyTo.join is not a function
at VueComponent.initWizard (webpack:///./src/router/index.js_+66_modules?:2813)
at VueComponent.openEditBackupData (webpack:///./src/router/index.js+66_modules?:3288)
at click (webpack:///./src/router/index.js+_66_modules?:3488)
at invoker (webpack:///./node_modules/vue/dist/vue.esm.js?:2024)
at HTMLAnchorElement.fn._withTask.fn._withTask (webpack:///./node_modules/vue/dist/vue.esm.js?:1823)
Out of curiosity, why would you want to put a retention policy ? The rsync script is made to mimic Time Machine (Mac) behavior which fills the hard drive until free space is exhausted. From then it purges the oldest backups to make room for the next one.
That way your backup disk space is used as efficiently as possible.
I think you may have missed a point here; moreover youâre taking risks by modifying the script since it will be probably overwritten by future updates.
