Authenticate raspi2 against Nehtserver openldap
Hallo,
I have some problems with authentication my Raspi against openldap of nethserver…
I tried this howto: http://www.techgeeks.org/blog/2015/07/13/raspberry-pi-ldap-authentication/
I used in my config files.
ldapuri://ip:389/
base dc=directory,dc=nh
binddn cn=libuser,dc=directory,dc=nh
I extracted the bindpasswd with
cat /var/lib/nethserver/secrets/libuser
But on my raspi I cant see any user from ldap with getent passwd. What can I check else to solve this problem?
Some usefull hints are welcome.
with warm regards from Leipzig
Denis
Hi , you need to make Ldap reachable from green lan interface, even it is better useing Ldaps 636 port.
Hallo Artem,
thank you for your response.
This port is open by default for the green network. I added the ldaps port by a seperate firewall rule.
The result is the same not ldap access…
when I use
ldapsearch -D cn=libuser,dc=directory,dc=nh -w PASWORD
from raspi then I get following result:
# extended LDIF
# LDAPv3
# base <dc=directory,dc=nh> (default) with scope subtree
# filter: (objectclass=*)
# requesting: ALL
# search result
search: 2
result: 32 No such object
# numResponses: 1
normaly I should receive the whole ldap tree.
Denis
Make search by existed domain tree, i did not remember default tree name
ldapsearch -h 192.168.1.1 -D cn=libuser,dc=directory,dc=nh -w
Maybe my how to will be helpfull :
@denis.robel how is it going? Did you resolve?
Hallo Alessio,
yes I solved the problem few minutes ago. I made a reconfigure of nslcd libnss-ldapd ont the raspi:
dpkg-reconfigure nslcd:
ldap://server-ip/
search base: dn=directory,dn=nh
authentication: simple
LDAP-database user: cn=libuser,dn=directory,dn=nh
password: from file /var/lib/nethserver/secrets/libuser
dpkg-reconfigure libnss-ldapd:
I choose folowing:
hosts
passwd
shadow
groups
It would be good if there could be the automount scheme be integrated ín nethserver ldap.config by default…
with warm regards from rainy Leipzig
Denis
