Are appointments/calendar items a one way sync when using mobile devices (Android right now.) If we create or edit an appointment on the phone, it does not push to the server. Created in SOGo and they push to the phone almost immediately.
Thanks!
Thanks!
Ehi Chris from U.S. welcome here
What are you using for sync? CardDav sync or Activesync?
Thanks.
ActiveSync.
Any thoughts on this?
Solved: rebooted the NS for an unrelated event and two sync works now.
