NethServer Version: 7.9.2009
Module: Mail
Hi there,
Trying to enable email to unknown recipients.
echo '{"action":"edit","domain":{"DisclaimerStatus":"disabled","TransportType":"LocalDelivery","RelayHost":"","name":"drain.riff.cc","Description":"The drain","AlwaysBccStatus":"disabled","AlwaysBccAddress":"","UnknownRecipientsActionType":"deliver","DisclaimerText":"","isPrimaryDomain":"","unknownRecipientMailbox":{"name":"wings@riff.cc","type":"user","displayname":"wings"}}}' | /usr/bin/setsid /usr/bin/sudo /usr/libexec/nethserver/api/nethserver-mail/domains/update | jq
These are the errors I’m getting:
"progress": "1.00",
"time": "4.978139",
"exit": 0,
"event": "domain-modify",
"state": "done",
"step": 3,
"pid": 14240,
"action": "S90adjust-services"
"pid": 14240,
"status": "failed",
"type": "Error",
"attributes": {
"event_name": "domain-modify",
"event_args": [
"drain.riff.cc"
"message": "domains.api_update_failed"
