Anacron job cron daily about netdata
On a non-subscription test nethserver I got the following email and thought, I should report here.
/etc/cron.daily/0yum-daily.cron:
The current config file can be downloaded with the following command
curl -o /etc/netdata/netdata.conf http://localhost:19999/netdata.conf
Config should be edited with /usr/libexec/netdata/edit-config
Any action required?
No, it’s just a message from a netdata update.
Thank you for your confirmation Giacomo :+1:
